so the pin that engages the clutch is sticking out to far I think so when I screw on the sprocket cover it tightens it down and put the bike in free roll i tried adjusting the clutch plate and it doesnt make a difference. pls help??
Bucking bar (5/16 shaft and ball) 1-1/8" long. Should stick out about 1/4". Never heard of a bar cut too short, but I suppose it can happen. You must of have other issues.ok Ill prob grind it down its just weird cause i had it running fine for a good hour then I stopped at a stop sign pulled in the clutch lever to stop then let it out and it wouldnt engage took off the sprocket cover and discover the bar was pushed out only a couple MM or so.
