Predator performance package
F_Rod81
Dealer
Jan 1, 2011
1,031
2
Denver, CO
I have a few parts for sale not just limited to the predator 79/99 obviously :).
Predator performance package includes=
- billet manifold sized for the 79/99 engine
- dellorto 15.15 carburetor with throttle cable (no filter) (70 jet size)
- 18lb. valve springs
This package will open up your predator pretty good. Not as good as other more expensive setups, but for the money and compared to stock this should give you at least 5-8mph on the top-end depending on your tuning ability. Bolt-on and go in 15 minutes.
$50 for package shipped
If you don't have predator, no worries, the billet manifold is wide set (40mm) and will work on grubee 66cc engines. Also have a Dax High compression head that has never been used. Parts individually too there just sitting here...
- dellorto 15.15 carburetor (no filter) - $20 shipped
- Billet intake manifold (40mm spacing) - $20 shipped
- 18 lb. valve springs for clone engines - $15 shipped
- Dax high-compression head (unused) - $20 shipped
F_Rod81
Dealer
Jan 1, 2011
1,031
2
Denver, CO
Do you still have the springs? And will they work on the 79cc PREDDY?
I do. Yes they will work perfectly on a 79cc :). I just installed some on a friends 79cc and he gained some good top end. The only thing that needs to be set other then the valves, is the coil air gap. From factory spec to a .021 gap.
PM me if your interested and I'll send you my paypal info.
Frank
