Hello to all on the Forum.
I received my engine kit, and all looks good. Had to clean up a little bit of casting flash off of some of the parts. My kit has the pull-starter on it. I have not mounted the engine to the frame yet.
My question is: If I engage the clutch, should I be able to turn the drive sprocket by hand with little or no resistance? It seems that with the clutch engaged, if I pull on the pull-starter ,the drive sprocket will turn. I tried to keep it from turning by holding it with my hand, but it is too strong.
With the right side cover off, I can see the clutch plate moving in and out when the clutch is engaged/disengaged, so I don't think the mallet-on-the-mandrel trick is needed.
Maybe it's because everything is new and not broken in? Once the engine is installed, and has the additional load/resistance of the rear wheel will the problem be gone?
Thanks,
-rohmell
Thanks,
-rohmell
