How many degrees can you rotate the drivetrain on the Lifan / Loncin 50cc -70cc full automatics . Or input on rotating any of them for that matter.
Thanks
Thanks
(tilting CRF50 45° or more)
The head oiling will work but the oil pickup under the crank will not. You would need to figure out some way to get the oil to the pump pickup, probably not easy to do. Also the crankcase breather is at the back and would drain oil out. Also the crank decompression hose will be spit oil out like crazy which is why you cant hold wheelies a long time.
Silver State Cycles board tracker I got to ride at a Willow oval race last year.How many degrees can you rotate the drivetrain on the Lifan / Loncin 50cc -70cc full automatics . Or input on rotating any of them for that matter.
Thanks
Thats solid food for thought that i probably would've never have found , preciate itI'm fairly certain the transmission wouldn't be effected, but this seems still somewhat unexplored territory w/the horizontal four strokes - doing a bit of digging around this was the most I could come up with... fairly obvious & not very helpful I'm afraid;
i wonder if he modified any of the oiling system, its so clean i wouldnt doubt it , but on the other hand it looks like its a subtle enough degree hmmmSilver State Cycles board tracker I got to ride at a Willow oval race last year.
This motor was a clutchless 4 speed shifter.
do you happen to have a couple links or a quick part list or something along those lines ? i'm unfamiliar with bmi or the tav setups but i'm down to learn or lookYou'll be using only the jackshaft.... Won't matter
