Rattling drive sprocket in freewheel
deskman
42
california
So I've thrown all my parts together, and I just need gas and I can fire this engine up.
Tonight I've been playing around with free wheeling... My clutch is responsive enough... But when I disengage the clutch to free wheel I get considerable chain rattling... Almost sounds like a running engine. I've been playing with tension and it doesn't seem to make a difference. Chain also hasn't been getting caught.
The wheel doesn't turn nearly as well as it used to... Which I should have expected.
But I can't help but feel that it shouldn't rattle this badly.... Like the chain is rubbing against the housing.
So question:
This is the stock chain, does that have something to do with it?
It's a brand new kit, does the drive sprocket need to just be worn through use?
Is my rear sprocket un aligned? It looks good to the naked eye...
JonnyR
1,203
ronkonkoma, new york
3 things that will help you use a strait edge to make it realy is strait.
throw out the stock chain if its the 410( mountain bike chain size)it will last a day if that they sell HD BMX single speed chains at most good bike shops cheap investment to not have a problem and also see how well its greased inside the sprocket and i like a little in the teeth of the gears on the clutch side also.
