49cc generator
locutus_1
196
california
for all you guys talking generators i made my own solution
i got a free harbor frieght flashlight took the end out where the leds are they arepressed in.. got a laptop round battery inserted it into the light like a regular battery the led part you have to have almost stick out all the way.. so what i did was hot glue the end back in and it works like a regular flashlight.. will run for 20 hours or more since the battery is 4000 mah..
here are some pics.. also youll have to add some soilder to the ends of the battery.. as you can see it looks stock.. all i did was use black electrical tape on the end with the hot glue and used a hose clamp with and old bike reflector clip and mounted it to the ape hangers i have.. its as bright as the sun with only 7 led..
tell me what you guys think.. it was an apiphiny i had while on the john haha i said hmm i have a laptop battery and a free light till i can get my generator set up hmmmmm lol
http://i1201.photobucket.com/albums/bb350/locutus_34/S7302083.jpg
http://i1201.photobucket.com/albums/bb350/locutus_34/S7302086.jpg
http://i1201.photobucket.com/albums/bb350/locutus_34/S7302089.jpg
http://i1201.photobucket.com/albums/bb350/locutus_34/S7302087.jpg
i forgot to mention theres a ring a metal ring just soilder it to the outter part of the circut board this is the ground to the case of the flashlight they push it in till it lights up and glue
take into account you will need a lipo charger to charge and lipos dont like to go below 2 volts fully charged is 4 but if you have like me a 4000 mah one it might last a super long time just charge it once a month if you ride alot. if you go below 2 volts aidos battery and it wont ever work again... to get these take apart a laptop battery pack there are useually 10 of them see if it has 4 volts or3 or 2 and throw a charge if it holds over night your good to go;
just a solution thought id share
locutus_1
196
california
Re: Respuesta: Re: 49cc generator
im making more than one so its no problem. im uploading another video you guys may find interesting.
good to have more than one idea.shft. you guys posted trying this so lets see if i can make changes for ya :)
YouTube - one phase 2 stroke magneto rewind 80feet of wire
please vote on my vid
cheers
is the one your useing off a old fan motor or something?
i have an old one 120volt has nice windings and a 1 amp fuse inside i was thinking of useing it just cut it to a round shape to clear. the magnet
but i wasnt sure if it would actually produce anything seeing how its wound for a small house fan...
then i decided to do the little mini light instead of this but its only temp till i can figure out how to do this... i do also have a rectifier from a power supply to give me dc now all i need is a charge unit to charge a batter or just wire up to a light from the magneto.. my ? is do you think i shoul dleave the stock windings alone and test it out? no harm no foul i guess
abikerider
219
Sacramento, CA
I just installed a tachometer and so was able to do some quantitative testing of my alternator using my Fluke 87 multimeter. I've attached a graph of the results. Output varies from 2 to 8 watts to a 10 watt LED headlight. This is after trying various tweaks so I think this is the maximum output for this unit. The LED headlight is quite bright! I also have 10 units almost ready for testers.
abikerider
219
Sacramento, CA
Thanks, I don't think I would've done it if I didn't like tinkering so much. I like the experimenting part more than trying to produce units to sell. Hopefully there's enough demand to make it all worthwhile.
BarelyAWake
7,194
21
Maine
While we allow product development in other sections as such examples, tips & feedback assist our memberbase - this is a primarily DIY forum and all posts made with a commercial intent (self promotion, pricing, etc) must be confined to our Swap and Shop section to protect the integrity of the information found on our forum, as per our rules: http://motorbicycling.com/f21/please-read-these-simple-rules-2.html & http://motorbicycling.com/f21/attention-vendors-8015.html
Feel free to add a link to a Swap and Shop thread in your sig and/or contact members/vendors by PM or email.
