So I've moved houses and somewhere along the way lost my manual and need your guys's help on hooking up the electrical components since that's the area where I'm the weakest at. .
Here's a pic of the wires. I assume the blue and black wires coming out of the magneto case on the engine go the the blue and black wires on the coil (blue to blue and black to black...seems logical). But what bout the white wire? I've read on here that some of you cut it off and don't even use it.
And finally there's the yellow and black wires from the kill switch (seen in the bottom right hand corner of the image). Where do those go? Or should I just forgo the factory kill switch as some of you have and rig up a different arrangement?
A diagram of the wiring would be greatly appreciated. Thanks in advance.
