Hello people. I did a fair bit of searching before posting this and got similar results but wanted to customize my problem more. I had someone install a huasheng 4 stroke kit onto one of my bikes and the bicycle will not stay running . I have tried adjusting the idle screw but it didn't make a difference. It's still a practically brand new kit with only 20 minutes of use ( testing) the motor has oil and there is gas in the tank. Is there something else I should check for? Bear in mind that I have no knowledge of mechanics or troubleshooting so please take it light in explaining things and please define any terms you use and how I would access these parts.
Basically, the guy who built it didn't test it out. And he lives 3 hours from me.
I'd rather learn how to diagnose and do the repairs myself as to not travel back-and-forth for simple things. So I pull the string on the motor to get it started, and then the guy said that once started, I turn the gray switch to keep it running. I do this, and it idles for a little while then completely shuts off
Thanks
Thanks
