just stopped by to pass on some information from some tests I ran this week. You do not need a speed controller to have an adjustable speed motor. If you wire a 24v battery pack from two 12v batteries you can set them up so that you get 12v, 18v, and 24 circuits. You need two switches. one for the 12v circuit and one for the 24v circuit. 12v on 24v off equals 12v at the motor... 12v off 24v on equals 23v at the motor... both 12v on and 24v on equals 18v at the motor or slow med and fast about what a controller really does.
the wiring is simple.
but I warn you be sure your switch can handle the amps... and use fuses or breakers... or even a relay. Good luck
Sorry forgot to mention this will not work with brushless motors
