Engines need 3 things to run properly; Spark, Gas and Compression. It sounds like you are having a compression issue (bogging down) which can come from a blown gasket. My suggestion is to take some water in a spray bottle and with your engine started, spray each gasket. If your engine revs, you've found an air leak and should replace your gasket accordingly. Hope this helps!
