I have just recently removed the carburetor from the jug because suspecting an air leak. I suspect this area to be the culprit, because this was the only place I tampered with while installing a new air filter.
The only symptom I could describe at the moment is, every time I would put in extra power, the engine would just die and poof out a small, blue cloud of smoke from the air filter.
Here's a picture of the mating region-->
There was a fiber gasket that came with it-->
I am also holding a tube of permatex gasket sealant, which I want to use instead of the fiber...
My questions are...
1.) Is this where a silicon gasket sealant is applied? (over the black, plastic intake port?)
2.) Should I just use either the silicon or the fiber or both? I want to just use the silicon gasket sealant by itself, as I feel using both the fiber+silicon would just introduce more vectors for air leak.
3.) I didn't do any air leak tests (such as turning the engine on and spraying carb cleaner around the mating regions). I simply went by instinct with this one, because the intake/jug mating region was the only thing I tampered with, while I installed a new air filter... So I'm suspecting that's our culprit giving the air leak. What are any other regions I should suspect??? Could you point them out to me with some kind of diagram, please?? as I am kind of lost with the jargon sometimes (i.e. "manifold," "jug," "intake," etc.)
Lastly, here's a profile of my new project (less the engine), sitting in a lonely, sunday morning light.
Thanks everyone, I really appreciate it!
My questions are...
