Howard,
Just in case you've never installed shaft seals be sure to lubricate the shaft and the seal before installing. You can use whatever oil you mix with your fuel for this. Just don't install them dry. Also inspect the shaft for any gouge, scratch or roughness where it contacts the seal.
If I'm telling you something you already know, sorry, I'm not talking down to you but maybe another member will benefit from the advice.
