I have a welder, but it's a 90watt flux core mig, so I'm not sure how well it'll work on the bike's aluminum frame. I found a bit of JB weld though, which I can usually trust to keep things where they need to be.
I would like to go tensionerless, but I've run into a problem. I thought I had #415 chain, so I ordered a #415 half link, and it came in the mail today, but it doesn't fit. I needed to bend the outer part of it for it to fit my chain (see picture), which worked, but when I tried to put it on, the master link's pin was too big to fit into the half link. I didn't think i should force it, because that's not how a masterlink works. Also the half link generally looks thinner.
Now I don't know what size chain I have, because it has different measurements than every other size. The pin diameter is 5/32", and the only chains that fit that are #420 and #425. However, between the inner plates is 3/16", while #420 and #425 are 1/4" and 5/16. I really don't know what size it is, because everything on the chart (
http://www.azusaeng.com/chain/mcyclchn.html) has different sizes. If anyone knows this chain, the dimensions are below.
Pitch: 1/2"
Between inner plates: 3/16"
Pin diameter: 5/32"
Roller diameter: ~~10/32 or ~.3125 ( I don't have calipers )
picture:
http://i.imgur.com/J7yWL2d.jpg
