On my last motorized bike I messed around with hooking up a 6v 3w light system to my bike and although the engine would start ok and the bike did run ok...it was obvious that the light system was robbing some juice from the CDI. I pretty much came to the same conclusion that most people have and that is the white wire was pretty useless.
My newest bike...for spits and giggles I decided to go ahead and try the 6V 3W light system on it. I was completely shocked that it has absolutely changed nothing. The bike starts as easy as ever and runs up over 30mph with no problem at all. Seems to have the same torque on climbing grades. I just can't see where anything has changed at all and the both the headlight and tail light are working just fine. They are not blinding bright or anything even close to that, but they are both lit up and having no ill effect on the engine running that I can tell.
I was so shocked that I removed the magneto cover to have a look in there and it has one of those newer style mags in there that only have the four holes instead of six. It also looks much more professionaly built then the ones I am used to seeing that have laquer globbed all over them with rust and cold solders. This one is clean looking, rust free and the solder jobs look much nicer. So what I wondering, is this magneto actually that much better then the old style? Has anyone else with this new style magneto experimented with using the white wire and come up with positvie results like I did, or is mine just a freak of nature? Like I said...it is not real bright, but I was just shocked that it even worked at all and was especially shocked to find it didn't affect the running any.
