I... have..a plan...
YoungRatRod
157
Wichita, Kansas
Okay so you know the Chinese battery operated tail light turnsignal combo thing?
what if you ran it off the white wire? i mean its only 3 volts so in theory it should work? Am I right?
I have the light setup, but my engine is out of commission for a while.
I will keep y'all posted... Its good to be back :D
Rocky_Motor
367
Fort Collins & Boulder
the proper way to do it would be to use a voltage regulator. It's really not to hard to build, but I've built a lot of circuits so maybe im biased. The easy way is to use a resistor, you can find the value with ohms law V=IR. I is current, v voltage, r resistance. I can figure it out later after classes today if you like
Rocky_Motor
367
I forgot that it was AC. Works with incandescent bulbs. LED's are supposed to use DC.
so you need a 6 ohm resistor (that's tiny!) To drop the 3 volts if you pull all 500mA. But the spark plug may not have reliable sparks if you pull to much. You need to find out how much current the lights you have pull to figure out the actual correct resistor. You could do so but putting two double A batteries in series, putting a multimeter in series after the battery and before the light.
if you want to convert to DC. You can get a rectifier or make it out of diodes. That will drop your voltage some though. Which may be a good thing.
I plan on doing some things with the white wire and have it basically serve as the alternator portion of the engine. It's going to be difficult for you to run lights off of the white wire just because it changes throughout the rpm ranges. when I get my bike down here i'll be seeing what I can do with it. Shouldn't be to hard to build a current limited power supply to charge a 6 volt battery. Im surprised I haven't seen it here. Maybe I haven't looked hard enough yet
