hello. I'm working on my first bike and had some questions about gearing.
The engine has an 11 tooth sprocket.
3600 rpm
2.5 hp
This is the 2.8 Lifan
The bike has 26inch tires
I have a 35 tooth sprocket for the rear wheel. It's small and I'm not sure that it will work. You guys would know better than I.
The engine sprocket is #35 while the rear sprocket is #40/41. I figure a jack shaft would also fix this issue. Is this difference a concern on a jack shaft?
I'm wondering what jack shaft gearing options (tooth numbers) there are for this setup that would give me a good ratio for slightly hilly areas.
I don't need to go any faster than 30 mph and that's probably pushing it.
Thanks.
3600 rpm
2.5 hp
Thanks.
