I have a centrifugal pull start 48cc. It works good. now a stops the engine is stopping when clutch is engaged. Usually at stops it can stay on or if engine is to low I can hold the clutch lever till I am ready to go, it does not cutt off then. Now when stoping the engine drags when bike is going slow.When I disengage clutch the engine runs but then putting clutch on it stops immediately and cuts off. When starting I have to pedal hard to go engine to start again, and it boggles and is draging during starts and then cuts on at a decent speed. I am thinking of loosening the clutch wheel when it engages, cause it could be the problem.
