Throttle slide spinning
So I have riding here and there mostly to work,the throttle slide is spinning inside the carb so the notch where the idle screw is off center or turned way around .....there for I run very high rpms and have to clutch kill the motor!
Any ideas on how to fix this I search the forums so far did not find an answer
The motor is from bike berry,nt carb , no mods ( as it is not broke in yet),
Change the throttle cable even short it by 1/2" I am at a loss with this one,I tried to tighten the cable,made it worst as the handle will not turn ( at least very hard to).check for air leaks and not a thing but a wet engine from the cleaner I used.I can't think of anything else....any all in put will be wonderful and used.
