Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Heads and Cylinders
Heads and Cylinders All about your porting, compression, rings, cylinder and piston modifications to your bicycles engine
Old 08-11-2016, 05:58 AM
codyj528 codyj528 is offline
Default Re: Slowing Top Speed
Originally Posted by maniac57 View Post
Using so much oil basically triples (or more!) break-in time due to rings being overlubricated and unable to properly seal to cylinder wall.
Break-in means rings seating and too much oil can easily prevent it EVER happening.
Poor compression, poor manners and reduced power are usual results of too much oil.
I'd bet $50 your jug was basically new inside regardless of prior use, so it ran like a new top end: poorly.
Meh. I couldn't remember the spec sheet but it was more like 20 or 25. Whatever the Chinese called for. And it had about 3 tanks of fuel ran thru it so I'd consider it a ok broken in. Besides. This isn't a gt500 break in.... but you know we drove that thing like a stolen car the first 5 miles off the lot on a 4 hour road trip home. Let's just say my Datsun couldn't keep up.
Old 08-11-2016, 06:00 AM
66cc motor bicycle https://imgur.com/gallery/8Rc4U
Old 08-11-2016, 10:20 AM
Kioshk's Avatar
Kioshk Kioshk is offline
Originally Posted by StevenMain View Post
...fuel sloshing from the slight vibration, or maybe the bowl is running dry due to a filter restriction idk. Any thoughts ?
BINGO.
I've had the same "problem", but I think it's a good thing. It's either that the carb-bowl's fuel is aerated from sloshing (doubtful), or there's not enough fuel getting in at high-revs (probable). Hold down the tickler with your left-hand when it starts happening again and report your findings. Better yet...for safety purposes...bring along a small child for the ride and have them do it.
Old 08-11-2016, 03:20 PM
StevenMain StevenMain is offline
Hold down the tickler ? What? Lol
Old 08-11-2016, 05:16 PM
Kioshk's Avatar
The goldy thing!
Old 08-11-2016, 06:12 PM
I have a keihin 20mm there is no primer.
MotorBicycling.com
