Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips and Motorized Race Bicycles
High Performance Bicycle Engine Tips and Motorized Race Bicycles We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. Also check out some of our racing members builds
Old 01-01-2016, 01:26 PM
sbest's Avatar
sbest sbest is offline
Default Re: 20mm Walbro on a China Girl
Cutting an old cylinder in half is an excellent learning tool.
This was a Yamaha Blaster cylinder cut apart as a learning tool:
From what I learned from it I stuffed it with several tubes of JBWeld epoxy in this manner (photoshopped):
Which in real life looked like this comparison:
The result was easier carb jet tuning because of fuel staying in suspension, wider powerband and of course, more power.
All gleaned from studying a sectioned cylinder.
Steve
Old 01-07-2016, 06:24 PM
chrisme chrisme is offline
Where did you find that carb / what model is it? I've been having a hard time finding a non-return style carb with an external pulse line. You've found just what I'm looking for.
Old 01-12-2016, 08:35 AM
cannonball2's Avatar
cannonball2 cannonball2 is offline
You can also use the carbs with the internal pulse passage just by Dremeling a small channel/port into the manifolds carb mounting flange to allow the pulse in the intake to reach the port on the carb.
Old 01-12-2016, 09:14 AM
Sure, however It would be nice not to have to deal with a fuel return. The external pulse port is just the icing on the cake with this carb!
Old 01-12-2016, 10:16 AM
curtisfox curtisfox is offline
Can one just take the return line and hook it the main fuel line from the tank, instead of going all the way to the tank?.............Curt
Old 01-18-2016, 01:14 AM
FFV8 FFV8 is offline
Porting the pulse circuit in to the intake is not the best plan.
The fuel pump was designed to work with the crankcase pressure pulse as well as the intake vacuum. That drives the diaphragm both directions.
With vacuum only, you get a half stroke of the fuel pump. This can make the high speed tuning very sensitive as the fuel pressure drops at WOT.
I have carbs and manifolds on the shelf. Just finished making a new batch of throttle arms too.
Old 11-09-2016, 05:26 PM
mike carter 2 mike carter 2 is offline
cool kit . are you still makeing them?
MotorBicycling.com
