Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips and Motorized Race Bicycles
High Performance Bicycle Engine Tips and Motorized Race Bicycles We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. Also check out some of our racing members builds
Old 08-10-2016, 09:19 PM
Venice Motor Bikes's Avatar
Default Re: 54 Schwinn 24'' DX My Next Race Bike
Genius!
Follow VMB on facebook>>> facebook.com/VeniceMotorBikes
Follow VMB on Instagram>>> instagram.com/venicemotorbikes
Old 08-10-2016, 11:03 PM
curtisfox curtisfox is offline
KOOL BEANS! will remember that. ................Curt
Old 08-11-2016, 01:49 PM
3dmotorsportLLC's Avatar
3dmotorsportLLC 3dmotorsportLLC is offline
Originally Posted by msrfan View Post
I just communicated with Danny at 3D and his E-Z Pull lever has the pivot closer to the cable end that does mostly what my modification did. I may end up with his lever. He also suggested a spring added to my lever to get a stronger clutch feel, so I installed a spring in the cable. Now I think it's just right. I hope all this info helps someone else in their 3D instsllation. Although A larger 4 stroke should be just fine without mods.
Real nice job on the modification. Would you be able to tell me what the ratio's of your current clutch lever are? I'd like to know distance between the pivot and the cable barrel, and also distance between the pivot and right around where your ring finger would be on the lever. Curious to know how close your ratios are to the EZ pull lever we sell.
Danny Downs- Owner of 3D Motorsport, LLC
Check us out at http://www.3dmotorsport.net
Old 08-11-2016, 02:48 PM
msrfan msrfan is offline
Sure. Lever pivot to cable barrel around 1.065, pivot to ring finger 3.753 or so and clutch center to cable stop barrel approx. 2.835.
Old 08-11-2016, 08:06 PM
MotorBicycleRacing's Avatar
MotorBicycleRacing MotorBicycleRacing is offline
Dale, Awesome bike!!!
Old 08-13-2016, 07:08 PM
Thanks for the info. Here is the specs for our EZ pull lever:
Distance between pivot and ring finger: 5"
Distance between pivot and cable barrel: 3/4"
The EZ pull lever gives about 6.6:1 ratio between movement of the lever and rotation of the actuator.
Your setup without the extension provided a 3.5:1 ratio. With the extension, you're at 7.7:1.
I'm sure that given your low power output, the 7.7:1 ratio is a huge advantage.
Old 01-05-2017, 01:58 PM
I just received my new levers from 3D Motorsports. Quality is tops. One has a locking button for the clutch and I'm using the regular one for more leverage on my front brake, plus they match. I'm going to try to install a spring on the lock out lever to return it to unlocked position so it will snap back on it's own instead of having to push it the opposite way to release.
Old 01-06-2017, 01:55 PM
I modified my new lockout clutch lever with a return spring and will be installing it soon.
Old 02-09-2017, 03:44 PM
Here's my new lever. Much better fit and improved spring return.
Old 02-09-2017, 04:04 PM
KOOOOOOOOOOOOOOL like it a lot better ...........Curt
MotorBicycling.com
