Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop
Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop Custom fabrication and projects, tanks, frames and more.
Old 09-23-2016, 10:09 PM
trackfodder trackfodder is offline
Default Lawnboy
I have an old 2-cycle 4 HP Lawnboy I dismantled to replace the case seals and replaced it with a 6-1/2 HP self-propelled 2-stroke that never slows down in 8" wet grass and weeds. Gotta love 'em. Anyhow, I think I will get some sch. 80 pipe nipples and put a 90 degree bend in each of 4 and thread the ends for bolts to mount the engine flange. Each can be directed to the best places to weld it in a Cranbrook frame. I have a Comet VST that has a 1" centrifugal clutch mounting hole that is just right for the engine. The engine served me well for many years , starting 1-2 pulls after sitting under a boat all Winter in the Spring As it will be moving, I don't need the shroud and may machine some of the cooling fins off the flywheel. I had previously adapted a #40 sprocket to the Comet, but I also have an assortment of #40 rear sprockets from an old dirt racer. Might be a fun shop project for Winter.
Old 09-25-2016, 11:02 AM
WECSOG's Avatar
WECSOG WECSOG is offline
Default Re: Lawnboy
Sounds like an interesting project. I've thought about doing something similar.
MotorBicycling.com
