Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Mounting Techniques for Bicycle Motors
Mounting Techniques for Bicycle Motors Every frame is different. Share and ask questions about mounting your engine kit to your frame or rack
Old 04-18-2016, 11:05 AM
Soylentbob Soylentbob is offline
Default Re: Motor mount on a 24" bike
Originally Posted by 2door View Post
Here is a little 24" bike I built that required no modifications. Stock intake and carburetor, straight plug cylinder head and it fit perfectly. The engine does look bigger in a 24" frame but that isn't a problem.
Turned out good, so mine should work too.
Old 04-18-2016, 11:58 AM
brown brown is offline
Originally Posted by Soylentbob View Post
Yes picture would be great thanks.
You can adjust cut saddle to however thick you want. The thinner you make it the closer the engine gets to seat post and increasing the need for the offset intake manifold for carburetor clearance.
I still almost always cut a 1/4 inch off just so I can drop the motor some.
You can fine tune the thickness of the saddle to eliminate any chain tension-er. I also use shims I get from one of the vendors on the site to also adjust the drive chain as needed.
http://venicemotorbikes.com/shop/?pr...oning-shim-kit
Old 04-19-2016, 08:49 PM
Looks like it should work then. I'll be getting a motor for it soon so I'll see how it goes.
Old 04-19-2016, 08:50 PM
Attachment 82325
Hopefully these will not be too hard to cut to size.
Old 04-19-2016, 09:13 PM
You just want to make a straight cut. If you square it up in the vice you can let a hack saw follow the top of the vice jaws an then use a file to touch up the edges. If you don't have a vice find a friend who does. Only takes a few minutes to do.
Old 04-19-2016, 09:16 PM
When you get the motor you can try it without cutting the saddle. If you have clearance then just leave it stock.
MotorBicycling.com
