been a motorcycle guy for over 40yrs and discovered motorized bicycles a few weeks ago. i'm hooked ! built a schwinn swindler with a 2stroke. almost through 2nd tank of gas having a ball in the cooold.
#64 main jet, manic mechanic 40t, frt and rear brake with dual brake lever, squished the frt tube with a C clamp to use the stock spacing on the replaced studs. re torqued the head 3X now it has settled down, NGK b6hs, billet throttle, tractor supply #41 chain, Michigan Motor Bikes Chain Tensioner, changed both frt and rear peddle sprockets for a lower ratio to suit this ol man...
