After successfully getting the chains down to the right length and getting the 99cc bike up and running, I decided to give it a little test run. However, a few feet walking down the road and my right-side drive chain popped off.
When I looked down, the pillow block had "self-aligned" and adjusted the angle of the jackshaft to around ten degrees, throwing off the chain. I hadn't even considered the possibility, but now that I think of it there IS a little space between the bearing and the housing that I can see a little nub through.
So my question is this: Will filling this with JB-Weld stand up to the twisting force of a 99cc engine? If not, will the bearing hold straight if I just get someone to weld it or would it likely warp under the heat of welding? (It's a big cast iron 5/8" pillow block bearing)
One of these. You can see the gap I'm talking about in the black space to the lower right hand corner between the bearing and the housing.
