I'm starting on a build with a 25cc 4 cycle weed wacker motor. Of course it had no tranny just a clutched output shaft.
Can I use a jackshaft and a reduction tranny? I don't see whay not from looking at the 4 GT 5:1 belt drive trannys. I worked out some ratios and shaft speeds useing a setup like the Sick jackshaft kits.
It looks like it would work. Is there something I'm missing here? I mean you could run chain direct from the 4 GT 5:1 tranny to the rear wheel. So why not run direct from the motor to a jackshaft ending in a 5:1 reduction and from there down to a double freewheel pedal gear and then back to the rear axel cluster gear????????
Is this little engine not powerful enough? They are used on rear wheel friction drives so whay not like this??
Thanks for any help,
Roy
Roy
