just finished install on grubby gt5 kit. thr problem is that the clutch is always engaged. The swing arm works when lever is pulled. The pin inside the drive sprocket gets pushed in like it should. removed cover opposite side of motor. the silver clutch plate gets pushed out away from the larger of the 2 gears like it should and the thing is still engaged. its still engaged with the silver clutch plate completely removed and no friction or pressure on the larger gear whatsoever. I'm having trouble disasempling the clutch any further than this, I'm not a small engine mechanic. some steps maybe on how to disasemble the clutch would be greatly appriciated.
