Greetings,
I have had a 49cc 2 stroke motor installed for a while, the motor is ridden in, however I had to get a new carby because the carby seal around the intake manifold had broke after being tightened too much. It worked well and still works well but leaks like a brick toilet through the bowel gasket. This carby was easy to tune. It is sealed well regardless of the fuel leaks. The c clip was set on the second pin setting from the top, rich or lean?
I installed a new carby, the same NT size carby, this one seems to behave quite differently at exactly the same pin setting. When I accelerate it chokes a bit at low speed. When I disengage the clutch and stop accelerating the revs take a long time to reach low idle.
I am assuming this means there is too much air coming in. But after checking the seals and no air coming in I think it might be the pin setting. Maybe the pin setting is too lean?
As far as I remember, the c clip set high on the pin lowers the pin deeper into the jet, making the jet closed up, allowing less fuel into the engine, and making the mix leaner. The higher the C clip setting to the top, the leaner the fuel.
And the lower the C clip on the pin,the richer the fuel, allowing more fuel thru the jet, is this correct?
So if a C clip is on a higher setting, say the second one from the top, does this make more air as well as less fuel, and cause the engine to continue to rev slowly down in idle? I have been wondering if my engine needs less fuel or more fuel. or is it more complicated than that.??
cheers
cheers
