i have a gt5 with aftermarket sbp expansion camber jaguar ignition boost bootle jnx header walbron after market carb and a high performance head. cant get to idle
Have you tried screwing the idle speed screw in more?so i got rid of boost bottle . and checked for air leaks found none should get rid of the walbron carb and go to a simpler nt carb with smaller jets. how do you tell if crank seals are blown out or bad. here is what it does it starts great and runs fine as long as your working the throttle. when you let off the throttle it falls on its face simply dies. any advice will help and appereciated
Best performance motor on the market.i have a gt5 looking for a better built motor hows the pk 80 just wondering if there is a better motor with bearings piston and crank
Just thinking that if you have a GT5 you would only need the Arrow top end.i have a gt5 looking for a better built motor hows the pk 80 just wondering if there is a better motor with bearings piston and crank
