I'm not sure where to post this, so if its in the wrong place, feel free to move it mods. Ok, so here goes.
I noticed the other day that my clutch was a little loose, and for a temporary adjustment, I adjusted the tension on my cable by moving the barrel adjuster out a little. But I want to adjust it more properly, as the engine is a year and a half old, and I havent made any adjustments to the clutch in quite some time. So I have a few questions that I hope will give me a more detailed understanding of proper clutch adjustment.
I believe that my clutch pads may be a bit worn, and that is the reason for my clutch being loose. I know I can make the cable tighter, but since the pads are worn, should the clutch plate be brought closer to the pads? to do this, do I turn the flower nut clockwise, or counter clockwise (I think I know the answer to this, but want to be sure)?
The bolt that goes down into the crankcase that has a hole through which the clutch cable is routed, will moving it have any effect on clutch adjustment/operation? If so, should I tighten it (further into the crankcase) or loosen it (further out) to put more tension on the clutch spring? Will doing so make the clutch grab harder at lower rpms at all? Sorry for the newb-ish questions, I just want to make the best adjustments possible to my clutch for trouble free riding.
