Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > The Tavern
The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like.
Old 03-14-2017, 01:38 AM
MEASURE TWICE MEASURE TWICE is offline
Default Re: Snork
As I think about it now and the topology of knots, it may have been the handle bars had been spun around. So I may have spent a little extra time undoing it the more careful way. But even with the two spins around the neck, I also saw it wrapped around at least one other cable. I like to have the largest radius curve possible so I was sure to do that without loosening the cable clamp. Removing the screw to the boss holding down one half with a brake shoe is easy. Some have that thread lock goop, but it comes apart.
I've been real fast at removing the cable this way as you'll see. It is I need to pack my non-road bike (OHV Legal Only) in my truck and so every time I do egress I am taking and swapping handle bars. The ones that are for the motor bike with both brake cables, throttle, & kill switch just stays with bungees attached to the bike tucked out of the way temporarily.
I do this as the other handle bars are ape hangers and are useful for transport so I don't put out a window. It acts as a wedge in place arrangement. For safety I have just the front brake lever and cable on the ape hanger handle bars and use the front brake to assist when it comes down a ramp. 130lbs and with the new Honda pegs and my adapter bracket to make them level and true, I think another 7lbs will be added to that when I'm done.
I also today had a passerby need a patch on a tube. The guy had been walking a long while and a significant other was riding her bike slowly next to him walking. Afterward he gave me 5 bucks. I was going to refuse, but relented
Mostly it took time away from getting the 2nd adapter bracket I was making, but I should have it all finished to go trail riding soon.
Pics of the way I have been getting jigged up (sort of), holding parts at just the right angle before welding all together. A snipped piece of thin sheet metal welded with just a few spots on one half and then position and weld the tab of thin mental on the other half. This thin sheet metal can actually have compound angles bent in it to a small degree and hold in place. Then the edges of the bracket parts almost 1/4 inch thick are also just test small weld.
Check again for alignment and if a go, weld up complete. Otherwise, I'm not too far behind, I break out the die grinder and nudge the thin metal into place. Grinding and flap disk sander on the angle grinder and no one ever knew that the stuff was even there. Power tools!
http://motorbicycling.com/showthread...588#post652588
Got It Pegged Thread
Old 03-14-2017, 01:33 PM
Chaz's Avatar
Chaz Chaz is offline
Default Re: Snork
I like your method. I will use it. I've played the good Samaritan a few times since I carry tools on every ride. It sounds like you and I were brought up in the same era.
I shudder to think how things will be when the selfie generation is the majority.
Just a chimp with a gun and an idea we should be free to ride our machines without gettin hassled by the Man.
Old 03-14-2017, 10:52 PM
xseler's Avatar
xseler xseler is offline
Default Re: Snork
There will be a 'tipping' point to where skilled craftsmen will earn more than the techies.
Sometimes, the truth is funnier than fiction!
You're never lost until you run outa gas.
Old 03-26-2017, 12:58 AM
Dan's Avatar
Dan Dan is offline
Staff
Default Re: Snork
Just so dumb and a waste.
Well, might be good that crime is so down in NYC that they have the time and resources;
"NYPD cracks down on illegal e-bikes in 24-hour blitz"
A blitz I tell ya, a blitz! lol
http://www.amny.com/transit/nypd-cra...itz-1.13308779
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 03-26-2017, 01:33 AM
xseler's Avatar
Default Re: Snork
May you have a "dryer sheet" kinda day!!
(People don't find you shocking, you smell good, and **** don't stick to you!)
Old 03-26-2017, 06:40 AM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: Snork
That bites, NYC must want to collect taxes on everything. Next they will charge people that have any kind of bike.
Your results may not be the same,Greg
Old 03-26-2017, 06:57 AM
Default Re: Snork
Next Soylent Green ... Yikes!
Old 03-26-2017, 10:02 AM
KCvale KCvale is offline
Default Re: Snork
Well that sucks, it looks to me like they were targeting bicycle messengers.
KC's Krusiers Builds
Old 03-26-2017, 10:47 AM
Ludwig II's Avatar
Ludwig II Ludwig II is offline
Default Re: Snork
The city wants clean air and everywhere else is encouraging electric transport; this is sheer stupidity that needs eradicating and replacing by a strategy and good sound rules.
Old 03-26-2017, 02:00 PM
fasteddy fasteddy is offline
Default Re: Snork
N.Y.P.D. Tough on crime.
Steve.
MotorBicycling.com
