how to install piston rings without breaking them ?????
abefroman
103
new orleans
well, I've broken several rings and it's getting pretty frustrating. can anyone tell me some correct procedure for installing rings without breaking them ? I try to be as careful as possible. I put one end of the spring in the top piston groove and gently work it around, then put one end in the lower groove and work it around. sometimes it works, sometimes it breaks. is that normal ?
cheers
crassius
4,032
158
USA
grow your thumbnails a bit long, then expand the ring just a tiny bit to drop over the piston to the position you want
they make a ring expander tool that opens the ring as you squeeze the handle that does this same thing
