kind of hard to explain. the motor's sprocket on the bike i am using right now is set up like this. from outside to inside: sprocket, metal disc (split into three parts), the rubber gasket thing, spokes, rubber gasket thing, another metal disc, then nuts and washers. The problem is that if this setup is correct (please inform me of the proper way) the sprocket is too close to the frame and the chain will grind on the frame while riding. My question is if any of those pieces in this setup is unnecessary and can be removed in order to give the sprocket and chain some room. can i remove one of the metal discs or rubber gasket things (not sure what it is called), and which one? inside or outside of the wheel. (inside being behind the spokes and outside being between the spokes and sprocket).
