Bolt on front disk brake ?
Rusty1
50
U.S.A.
Is there such a thing as a truly bolt on front disk brake and if so where can I find it ?
This is my 1st project and I'm learning as I go . I apologize for asking so many questions . You guy's have been to kind .
Rusty1
50
U.S.A.
Thanks for the info . The bike that I have is a 29 inch with over sized tubing and I'm sure I wouldn't even be able to buy a front fork set up for it . So I guess its just out of the question .
Rusty1
50
U.S.A.
LOL . Thanks but the cheapest one on that page is almost double what I have in the whole bike . My budget would have a heart attach !
BarelyAWake
7,194
21
Maine
Perhaps - but as it'd hafta be a "clamp on" arrangement, I don't think I'd be able to trust it fully with the loads a front brake experiences...
...but there's some options available, the tricky/costly bits is the 29" size & if you're lacking a front disc hub as well, then you're looking at a hub, wheel build and front fork - add in the cost of disc & caliper... and suddenly you might want to consider just getting this & stripping it for parts & spares lol;
Genesis 29" Men's Mountain Bike
If you've the wheel, I'd check the local bike shops first, they very often have "take offs" - new or very slightly used front forks (& other components ofc) that the customer immediately upgraded from when they bought a new bike, then left at the shop 'cause they didn't want them or care. These parts can usually be had for pennies on the dollar, the shop more than happy to be rid of them. As 29" bikes aren't particularly common, this might be a challenge however.
Not to say it's impossible otherwise, disc hubs can be inexpensive and you can make caliper mounts yourself. This is steel & the rear wheel, but the concept is the same as any caliper mount (welding aluminum shocks can be tricky, best to disassemble & clean before applying heat);
