While looking around for information on another topic I found this.
https://www.youtube.com/watch?v=EOqWzefvlfg
https://www.youtube.com/watch?v=q-c6ySGYkWY
https://www.youtube.com/watch?v=19-GSB37IkY
We all have two stroke engines that don't run stuck in boxes under the bench, - sooooo perhaps this might be a good use for themDIY 2 Cycle to Steam Engine Conversion Project
http://www.tngun.com/diy-2-cycle-to-s... http://www.amazon.com/3-4-CHECK-VALVE... This project has been one of my favorites so far. When I first saw this concept, I was a little overwhelmed. I thought it was magic, and that anyone that could convert an internal combustion engine to work on steam had to be a genius. However, by the time I had enough projects under my belt to have the confidence enough to try it I found it to be simple.
I need to say this upfront. This project used steam under pressure; therefore there is an element of danger to this. Steam engines cannot be safely run unattended. If you are going to build this or any other steam project you must use some uncommon sense and work carefully.
Now that the safety issue has been broached, I will address the question my wife, mother, and coworkers that think I am crazy have asked repeatedly. That question is "WHY".
Well, the most obvious answer is I think it is cool, but what I tell my wife is that a steam engine gives me a redundant power source that does not need oil based fuel. I can go out and cut wood and convert wood into electricity. While this is not as efficient as a purpose built steam engine and boiler or a wood gas system it is much cheaper and simpler to build.
To make this project you need three components: a boiler, an engine, and a generator. We will cover the boiler and generator in later posts.
The boiler uses a salvaged weed-eater, but most any engine will work if you understand the process and can adapt to overcome. I used a weed-eater because it was free and the simplest to convert. You will also need a ¾ brass check valve, a pushrod, and miscellaneous plumbing bits and pieces.
The idea is to create a single acting steam engine (meaning the steam only acts on one side of the piston), by using a pushrod inserted through the spark plug hole to push open a the check valve when the piston is at Top Dead Center (TDC) so the steam will push the piston down just like the gas explosion does when it was a internal combustion engine.
The first thing to do is strip your weed-eater down to bare block. Just start unscrewing stuff, but leave the internals alone.
You will need to keep the flywheel attached to the engine, as you will need the weight to return the piston to TDC. Otherwise the engine will quit. I plan on casting a new flywheel (formulas for this can be found in Steven Chastain's book on inverters and generators), I just haven't gotten to that yet. Once you get the block stripped down you need to find a pipe nipple that will screw into the spark plug hole.
Your check valve will screw onto the other end of the nipple, but first you need to take some measurements. You have to create a rod that is long enough to push the check valve open when the piston is at TDC. It has too also be long enough to keep a portion of the rod in the pipe nipple so it does not fall into the combustion chamber, yet still be short enough to let the valve close as soon as the piston starts to move. If it is too long or too short the engine will either lock up or be hard to start.
An easy way to measure would be to screw everything together and measure the exposed length of pipe (that way you don't have to keep track of the amount that is threaded). Unscrew everything and rotate the piston to TDC. Insert a rod to measure from TDC to the top of the spark plug hole. The last measurement is from the bottom of the check valve to its open position. You do this by taking your measuring rod and pushing the valve open. Add the three together and that should be the length of your pushrod. Personally, I added a tiny bit to the measurement to account for my problem with attention to detail, and then used a file to custom fit everything. I kept assembling the engine and rotating the crankshaft to check if it would open the valve and cycle smoothly. To make this simpler I used a piece of old ink pen shaft as my push rod, with the idea I would measure it when I got the dimensions correct and make a new rod out of a metal rod. In actuality, I just glued a carpentry nail inside the plastic shaft and am pretty pleased with the results...Locations and Emergency Situations" http://www.amazon.com/gp/product/0970...
