I am in a bit of a sticky situation, having sheared off my motor mount studs.... I went to the store, and dropped 80 bucks on a damaged bolt remover kit. Using said kit, I drilled into the bolt, successfully, then switched over to the other "grippy" bit. It gripped, as it was designed to do, but then the damaged bolt remover, sheared off inside the sheared off bolt!
F**K!
Those things are made of the hardest metal ever.... no hacksaw, drill bit, or dremel seems to be able to even dent it. So here I am, 80 bucks poorer and in a stickier situation than before....
So, I seek advice. Aside from scrapping this engine (I would rather not, since this is my best performing engine) how can I fix this situation....
F**K!
