Building a DIY weedwacker rig takes a lot of custom crafting. If you can do that, you shouldn't be afraid to play with the carb. If you don't already understand 2-cycle motors, the best way to learn is by experimenting as you go. As I said before, I highly recommend modifying the carb screw so you can adjust while riding, but it's not crucial, you can always hop off and adjust if necessary. But you should definitely have the choke positioned where you can adjust it while riding. Working the choke lets you know if the motor is running rich or lean and if the carb needs adjusting.
