Centrifugal Clutch add-on kit
Cabinfever1977
2,288
Upstate,NY
heres what it said about my dualstart dualclutch engine:
Dual GGG model; Allows pedal starting as well as rope pull engine start. Uses a friction clutch as well as a special centrifugal clutch with over running clutch lock up to pedal start; Handle Bar Clutch lever must be in the engaged position to operate in centrifugal clutch drive mode. In disengaged lever position the engine is in free wheel mode separated from drive line. Note: A standard friction clutch engine can not be converted to GGG dual mode due to different crankshaft
POPS
310
Vancouver Island BC .Canada
Hi Cabin
I do not know what Dual GGG means but You can buy the pull start and C/F clutch
from Zoombicycles but they will only fit on the 69cc motor. From what I read they will not fit on the
49cc. I bought 2 kits and they were real easy to install...POPS
rohmell
1,531
6
New York
I bought a centrifugal clutch kit from ZoomCycles.
The clutch has a one-way sprag-type of system inside of it.
The engine can be started by pedaling and releasing the hand clutch just as before. Once started, the motor can idle at a stop without use of the hand clutch.
Dan
Staff
May 25, 2008
12,765
115
48
58
Moosylvania
Sounds purty cool Rohmell. Do you have any links?
blckwlfny1
128
new york
Does anyone know if the centrifugal clutch kits from gasbike/kings motor bikes can be pop started? I have one...how can you tell before installing it?
What about BGF? I may need 2 buy another kit
rohmell
1,531
6
New York
Hold the clutch bell in one hand and try turning the weight assy with your other hand. If it turns in one direction and both pieces lock together in the opposite direction, then it has the sprag bearing that will allow pedal starting.
