could use some tips on engine mounting
mattisbetter
Florida
id like to put an engine on a Firmstar rebel delux( pictured below)
im curious on how the mounting works on these since its not a "vee" frame.
i was thinking of using a Grumbee skyhawk 66cc 2 stroke.
what changes would i have to make to get this engine to fit?
thanks ahead of time!
MATT
TexasChopperGuy
Richmond, VA
I'm actually in the works of making a bracket right now for the same exact reason. My idea requires welding and gusseting of the bracket to the frame. I've also pondered about adding in a SRAM i-Motion 9 rear disc hub and setting up a SBP shift kit if at all possible. Any other input from more knowledgeable forum members on the bracket?
I'll be sure to post pics as work continues
mattisbetter
Florida
Thanks! and thanks for the tips.
its 13" frame
I dont know much about making custom front mounts so it looks like i will be doing a bunch of research for the next few days.
Ill post pictues once its finished.
venice motor bikes, i saw on your website you have some pretty sick bikes and you work on stretch bikes and choppers. Any other tips on building this bike correctly?
Al.Fisherman
1,966
Calera, Alabama
its 13" frame
Tips on both the HT's and mounting.
Pre build and engine modifications.doc
Engine Mounting pictures by Ron-Becker - Photobucket
