Chain Problems
techtiger
15
Springfield, MA
I've broken 3 chains so far riding around for no more than a mile or two. The sprocket is aligned and centered without wobble I made sure of that with some tape inside the sprocket hole for the hub. Am I putting the chain on too tight? It had about 1/2in of play. I'm running the chain without the tensioner. From the rear it was aligned as well. So its got me confused.:-||
techtiger
15
Springfield, MA
I got the 415 chain off of bike berry. Snapped about 8 links before the master link. On the right side of chain looking from rear. Maybe I had it too tight?
nightcruiser
1,180
USA
I can't comment on the quality of the chain you are getting, never rode one, but get yourself some #41 chain your problems would be over. It may seem a bit wide, but it runs smoother than the thin chains for me...
nightcruiser
1,180
USA
OK thanks I'll try it.
One thing though, since the #41 chain is so wide and heavy duty you can't split the links with a regular chain tool (I broke mine trying! LOL) I ended up getting the job done with a vice, center punch and hammer. If you don't want to go that route you should get yourself a chain tool that is made to break a larger chain like #41, should be able to get that tool the same place that has the chain...
Toadmund
792
6
Saint John, New Brunswick, Canada
Or you can get this, which one of our fine members suggested:
Nice friggin' chain man!
Note: may be short a couple links, mine was.
So I ordered 2 of these, 1 chain for my brother, 1 donor chain for him and me, I bought a nice chrome one locally, 2 black links, oh well.
With S&H to Canada it was cheaper (but not chromed) in cost from the LBS. (Local Bike Shop)
techtiger
15
Springfield, MA
I actually have that chain but the space pivot points were too large for the sprocket on my engine maybe cause I have the 415HD version instead of the 415H. Was a chain I had lying around the house.
Toadmund
792
6
Actually, I realized that I had a problem with that too.
My brother said, ah, don't worry about it, it'll wear in.
It went clack....clack.....clack
Tried to take a file to the teeth, no way, those teeth are hardened metal, you know that when you wear out a nicholson file.
However, the sound did go away and it did wear in.
Everythings good.
