what is 4 cycling?
taddthewadd
337
Visalia, California
I hear you guys talking about your engines 4 cycling. What do you mean by this and how can you tell it is doing it?
I understand the difference of how a 2 cycle and 4 cycle engine works but don't know how a 2 stroke 4 cycles.
Whizzerd
114
21
18
Muncie,IN
I'm no expert here but in 2 cycle model engines "4 cycling" is a rich mixture setting where the air/fuel mixture doesn't ignite every stroke. It's actually beneficial to longevity and you should notice under load like an incline the engine will break into a full 2 cycle for extra power. Without a mixture setting screw the HT engines require a carb dismantling to adjust the metering rod height to 'lean' or 'richen' the mixture.
Venice Motor Bikes
Mar 20, 2008
7,266
1,797
Los Angeles, CA.
Whiz... you hit that right on the head!
I'll also add; the way I can tell when I get the mixture just right is when it runs nice & crisp & has a very light 4 cycle at certain spots on the throttle! This way I know the mixture is right, but still a little to the richer side.) ;)
