muffler
hadog
I have been installing kits from ZoomBicycles for a bit now. I am on average happy with them
However their new kits have a black muffler that has a cat. converter in it....it totally robs the power, on some machines to the point that it will not go up an incline.
If I swap put the new muffler and replace it with an older style the kit is great.
Anyone have a fix for these restricting mufflers?
hadog
tes but I have 10 lits....don't want to get new mufflers for them all
can't gut the thing because it is all welded because of the catalitic (sp) converter
Norman
LORD VADER Moderator
Jan 16, 2008
2,606
7
71
pampa texas
you can gut the muffler by cutting off the end clean it out then reweld it. Paint it black with high heat paint. Or have it re chromed (expensive).
norman
Cabinfever1977
2,288
Upstate,NY
i have a black cat muff and my bike takes off fast and has plenty of power for hills.
and its real quiet at idle.but i like normans idea.
Forbisher
119
Orange County, CA.
norman
I doubt if the guy has a welder so it would not be worth the expense to
pay to have it done
The all welded black "cat"? pipes are junk
The black "cat" pipes from Grubee perform OK and have
a removeable endcap but the black paint burns off right away
The threaded screw holding on the endcap needs to be replaced
with a tack welded stud too
Would be easier and cheaper to buy a new one
The stock exhausts are badly designed for 2 stroke performance
Cabinfever1977
2,288
Upstate,NY
i have a black cat muffler from gasbike,the paint on it is still just like new,no peeling or nothing. the muffler is quiet and i though i had good performance until one day the muffler gasket blew out,i had all kinds of power and speed increases,it felt like i was on a motorcycle and it was just as loud as one. i had to replace the gasket because it was too loud for the street. maybe i could make a exhaust cutout valve so when im off road the exhaust would go out a strait pipe and skip the muffler and when im on road i turn a valve to direct exhaust threw muffler, they make these for hotrod cars.
i cant weld but i can drill a hole in the exhaust pipe above the muffler and install a open/close valve to bypast the muffler when i need more power. just a idea i probally wont get around to it.
matt167
420
usa
not if you run it to a straight pipe and reg muff.
if you bypass the muffler with a cutout and a straight pipe, you will create a lean condition and burn a hole in the pistion... it would require rejetting the carb to make it right.. a simple exhaust cutout like you find on hotrods wouldn't work, because 1 way or another it would end up lean
Cabinfever1977
2,288
Upstate,NY
i said straight pipe and regualar non restricted muffler. that i would be using 2 mufflers,1 cat black and one with out cat with a valve to switch between the two.
i dont rejett nothing. many people on here use a long straight pipe and small lawnmower muff at the end or none at all.
matt167
420
usa
a straight pipe is ok, but it would need rejetted or at least adjusted ( change the clip position ) otherwise the gained flow will cause it to run lean and burn up... even if you had a non cat muffler, and a cat muffler.. the flow charectaristics of the 2 would be diffrent. and at the very least, you would need to tune it to run the non cat pipe as it would flow more, but the mix would end up a little rich when switched to the cat muffler
matt167
420
usa
check your plug, I gaurentee you'll find it's burning lean... may take a while, but if you have increased flow thru your exhaust than you have leaned out your engine and it will be detrimental to the pistion... this is why so many kids burn up there dirt bikes.. aftermarket pipes without rejetting.... air cooled engines are very easy to tune, but they need tuning when modding... you can't just expect them to run without being tuned once in a while even un modd'd
Cabinfever1977
2,288
Upstate,NY
i havent increase no flow threw my exhaust,i am just using a black cat muff.
and i was saying they are restrictive but are quiet. and that using a regular muffler you would have more power. and that a cutout would have been nice,but was just a idea that someone else had metioned on another post. im too busy to play with the muffler,i have chains and mounts to keep me busy.
and my sparkplug is just fine.
matt167
420
usa
you were talking about the cutout, so I assumed you had that setup, or changed the pipe out with something less restrictive.. if you just have a cat muffler, then that would be a basic stock setup, and as long as it's burning right, it'll last a long time.. but if you ever did, it would need some carb adjustment..
xlite
735
ny,ny
It happened to me a couple times. Much more power. Once I put on couple hundered miles like that but the noise is unacceptable in the city so I put a new gasket on.
Maybe it's like running with no air filter, more power but not good for the bike. It didn't seems to hurt my engine but who knows if it ran like that for a long time.
Some time ago they had a gimmick for the exhaust that was a washer which muffled when it blocked the pipe but could be turned sideways for power. I'm think of trying it myself.
TheE
185
Canada
I got my bike from ZoomBicycles too and also got a cat hush muffler. ZB is aware that these mufflers rob power, and they say they're looking into getting better ones. Still, you can modify them easily enough. They have some good how-to's in the forums.
