Upgraded chain
Flounder
65
Jacksonville Beach
Hey people.. I just want to throw this out their. The chains that come with these kits are nothing but junk..They stretch and stretch and constantly pop off....Throw them AWAY!.. I just put on a #41 chain
yesterday and have had zero problems... My bike was setup perfect. All my problems were the results of an inferior product.. You can save yourself's a a lot time and grief by running down to Northren tool and picking up a Drive Chain #41 | Chains + Sprockets | Northern Tool + Equipment and dont forget a
Heavy Duty Chain Breaker..
usflg
FlyingHorse87
24
Jeannette, PA
The chain that comes with these kits isn't the best, mine stretched significantly over 3 days of running, that could also be attributed to me riding up very steep hils and weighing 250. I replaced mine with KMC 415H free style chain, it was arond $13.00 and is much higher quality than the original. Another easy way the seperate chain without a chain breaker is to carefully grind down the pins on a bench grinder WEARING GLOVES, then put a chisle or large straight blade beater screwdriver between the side plates and tap it with a hammer. They will come right apart with no damage.
Evan
Chrismbello
39
Gainesville
usflg
Just wondering, will that chain breaker work with the 415 chains?
Thanks,
Chris
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
N.M.
I am not totally familiar with this chain stretching out deal. All my bikes that were stock I did run teisoners on them usually upgraded to a custom shaped skate board wheel was the only set up I ever truly liked . Much smoother than the stock wheel in the kits huge difference. All my friends around me so far including me never had a problem with the stock chains. My first kit I put about 6000 miles on the kit chain and motor. The out put cog on the engine had a lot of wear though. It never missed a beat.
xzackx
44
morgan county, OH
i just got done ordering #41 chain too because my original chain was not long enough for my schwinn stingray, so far its been running pretty good
Flounder
65
Jacksonville Beach
I use the stock chain. I never had a problem, besides with stretching, which is what the tensioner is for.
The tinsil strength on these chains are 2800lb compared to kit chains which are 1200lb tinsil.
Less stretchy more ridy =)
I know kits vary ...My troubles come from the gt5 kit..Being the only kit I ever owned.
xzackx
44
morgan county, OH
i bought a #41 roller chain in a 10ft section and i had to use 5 feet of it for my chopper i used a dremel tool to grind off each side of the middle pin and used a punch to knock it out takes longer but works
