Odd sound and smell
sboricic123
172
3
18
Bailieboro, Ontario
My 66cc china girl started making some weirds noisess like a popcorn machine or grinding sound. Plus it has an odd odour. I'm not sure if the odour is from the exhaust after switching oil brands. I'm running it at 50:1 with Amsoil. Any hints would be helpful as to what it could be.
crassius
4,032
158
USA
engage your clutch and push the bike forward & back a few inches - you will hear a clanking sound from the backlash of the clutch gears
when the engine is running with the clutch disengaged, the piston turns the crank when the plug fires, while the crank pushes the piston beween firings
with the clutch engaged and riding at speed, the weight of the rider causes the momentum of the rear wheel to push the piston faster than the crank does - this takes up the slack in the gearing, such that at higher revs you hear that backlash clank a lot at a rapid tempo
this is not something to worry about
as far as the smell goes, look for wires, muffler paint, or your pant leg getting burned by the heat of the muffler
crassius
4,032
158
USA
in that case, it could be as simple as the clutch dragging a bit or something really serious
look for leaks at gasket seams and try to find where noise is coming from with a stethoscope or a long screwdriver between your ear & engine
MotorBicycleRacing
5,844
109
SoCal Baby!!!
www.facebook.com
grinding?
did you take off all the covers and look for the source?
rotate the engine with the chain disconnected?
sboricic123
172
3
18
Bailieboro, Ontario
I have adjusted the clutch but that's all for now. The noise seems to be coming from the engine itself even when idling. Perhaps the pistons or something are on there last limb?!
sboricic123
172
3
18
Bailieboro, Ontario
I removed the flower nur and clutch cover and noticed the pads are quite worn out causing the plate they rest in to rattle and loose. Is that common for the plate to be loose? Could that be the noise and odour from burnt pads that I have noticed?
crassius
4,032
158
USA
yes, it will be loose without the flower nut - seals a bit too tight for smell to get out I'd guess tho
2door
Moderator
Staff member
Sep 15, 2008
16,302
175
Littleton, Colorado
Start here > http://motorbicycling.com/showthread.php?t=22726
If the smell is like burning rubber it is the clutch friction pads. My guess would be the clutch cable is too tight allowing the clutch to slip. Either that or you are slipping the clutch when you try to take off from a dead stop. You must pedal up to speed, about 10 mph before releasing the clutch. Remember, it isn't a motorcycle.
If you didn't adjust the flower nut properly the clutch might be slipping. We always suggest getting clutch cable tension right before messing with the flower nut. They are usually adjusted correctly from the factory.
Another thing that will cause your problem is over lubrication of the gears on the right side. Too much grease will end up on the clutch making it slip and smell.
