Can someone tell me the diameter of a 66 piston head?
Al.Fisherman
1,966
5
Calera, Alabama
Nashville Kat
1,501
55
48
Jacksonville, Florida
Thank you
or 117.5% of surface volume of the 50cc piston.
So it stands to reason, if the stroke is still the same- and boygofast at least seems to be advertising the same bottom end for both engines- at least with 6mm studs-
the 66cc is 117.5 percent larger than the 50cc, or then actually 58.75 cc?
What am I missing here?
Nashville Kat
1,501
55
48
Here's some math- correct me if I'm wrong-
and I don't know the depth of the stroke or the formula for cubic cc's
but isn't the surface volume of a piston head pi x radius squared?
50 cc motor- 40mm diameter means 20mm radius
20 x 20 (squared)= 400
400 x pi or 3.14= 1256 square mm.
"66" motor 47 diameter means 23.5 radius
23.5 x 23.5= 552.25
552.25 x 3.14= 1613.4065 square mm
the second figure should be roughly 117.5% ?
This is the surface area of the piston heads
It's obviously not - it's almost another 1/3 again- or 33% more- so I guess I'm leaving the pi r squared formula off the percentage figure.
33% more then gives us an 18.888 figure- making the motor, with the same stroke- actually a 68.888 cc motor
but of course I've roughed up on the figure to 33- it's not quite and I'm through doing math for the night.
so anyway it's then a little bit LESS than 68.888 cc so maybe 66 is pretty acurate
I think
interesting
