Cool Steve,,, thats awesome thank you
I would love to talk to you more when I get back from hardware store...Got an Awesome upgrade working on and if it works I will be selling it in a kit,,, Its what these bikes need !!!
A WALBRO WYK -192 15mm carburetor with HIGH and LOW speed adjusters,, I have the adapter / heat insulator intake mount (hard plastic/composite ) that has to slightly be modified to work,,, also there is a pulse hole on these carbs since they are diaphragm type and I need to find a way to connect it,, these carbs are also used on the 49cc 2 stroke scooters (( I HAVE ONE, THATS WERE I GOT THE IDEA)) on those engines the pulse hole connects to the engine thru a hole underneath the intake opening on cylinder..
If you look thru the tiny pulse hole opening right under the intake flange opening you can see the piston skirt going up and down creating an open / shut action as it passes by tiny hole..
I am trying to figure a way to hook up pulse hole and where too... I can hook up a little brass elbow tube coming out of isolator block ( as shown in picture)) ,, but where do I run a tube on it too...???? I saw one guy on here that ran it to a small nipple/tube fitting that was drilled and tapped into the transfer port on the bottom left of engine,, below cylinder where the cylinder meets the bottom case transfer port.. into the case wall thru the transfer port...
will this work and give it the pulse it needs ???? please help me with this Steve or anyone that is familiar with this...please!!!
If this works it should be like fuel injection,, as on the scooter there is no 4-stroking and screwing with main jets and needle clips... i got this Walbro WYK-192 off a brand new 72cc industrial leaf blower engine,,, so should work on 66cc... will try to get a bigger 18mm diaphragm carburetor in future if this works out good..
THE PICTURE OF CYLINDER IS THE INTAKE FLANGE ON THE 49CC SCOOTER ENGINES,,, SEE THE SMALL PULSE HOLE IN BOTTOM/CENTER... THIS IS OPEN AND SHUT BY THE PISTON SKIRT GOING UP AND DOWN OVER IT..
