Hello,
Bought a Little Evil 1 Kit from Dax. Spent a lot of time making sure it is installed correctly.
The motor will not fire.
We have spark. A nice blue spark. The spark plug is a new NGK, replaced the NGK that came with the kit.
The magneto is new.
The kill switch is disconnected.
The carburetor is cleaned and the float is working fine. Took the carburetor apart and cleaned it out. Not that it needed it.
It is getting air. Made sure that the muffler is not clogged. When the pedals are turned with the spark plug out you can see a mist coming out of the hole. Not so much a mist but you can tell that it is not just air coming out.
Thought the motor might be flooded. Took out the spark plug and turned the bike upside down. Turned the motor over using the pedals so that any excess fuel would come out. Drained the fuel tank beforehand.
Even used starter fluid. Not even a hint at starting.
The conclusion I have come to is that the timing is off or there is an air leak. Everything else has been eliminated.
I have this nagging feeling that I am missing something obvious.
I know that I am this close to riding the bike. I made sure that the chain line is perfect. Have replaced both wheels with good sturdy wheels. Am using BMX caliper brakes. Made the coaster brake into a free coaster. I have spent hours putting this bike together and am not going to give up easily. I have enjoyed the challenge of getting it right. I know that Dax makes quality motors and am finally reaching out for help.
Do you have any ideas?
Thanks,
Mike
The magneto is new.
Thanks,
Mike
