If you decide to go with the Staton Inc hub, be aware it isn't a flip-flop hub. The treads on the right side are right hand treads. The treads on the left side are left hand treads. So if you were putting a gear and/or left hand freewheel on it wouldn't come off. If you want to use a screw on type of disk for disk brakes on the left side, both sides of the hub will have to be right hand treads. A true flip-flop hub will have right treads on both sides. If you need both sides to be right hand treads tell David and he can make both sides the same. My Staton hub has held up very good. David will also lace the hub onto a rim at a reasonable price.
