any thing here look like it is built to fail?
tvc15
87
portland, OR
Hey, I wanted to see if anyone has any comment on my electra engine mount. I milled the support from aluminum this weekend to some pretty tight tolerance so it is secure with stainless bolt down the center. The bracket is aluminium now but I'm thinking that steel is a better option. Please let me know if you guys have some thoughts...THANKS!
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
If by "allow" you mean aluminum, by all means don't use it. Steel is the only way to go and it needs to be just a little heavier, thicker than what you have which looks to be about 1/8". I tend to build heavy but I'd probably go with 1/4" minimum. But that's me.
Mac
486
Maine
Concur!
The mount to the frame looks substantial, the .125 Aluminum "standoff" I feel will be inadequate for 3 reasons. 1. with that thin of a standoff you are concentrating the shear points on the engine mount hardware to a very small area of the bolt shank. 2. The material the standoff is made of looks like 1100 series Al.(looking at bend radius) soft, will bend torsionally, causing chain misalignment. 3. The right side engine bolt will be under tremendous load(think of the chain pulling back on the motor real hard), this coupled with vibration = Failure. Suggest using the same material as the frame mount, angle drill and countersink a new standoff so the end result is the entire mount is the thicker material. Just my 2 cents. Still a good job!
Mac
Kevlarr
1,628
Mi
Kind of confused, if you have access to a mill why not make the entire mount one piece extending from the motor right down to the frame?
Do away with the standoff entirely.
