milling question
1,668
12
Clearwater, FL
web.tampabay.rr.com
for the machinists out there....well jim and ret
can you mill a square tapered hole to fit onto a 3piece bottom bracket?
It's called a broach. You drill a hole first, and then use an arbor press to push a broach into the hole. The broach shaves the metal out of the corners. This is also how straight key slots are cut.
It could also be done with a wire EDM, but it would be expensive.
The milling machine will always leave a radius in the corners.
Jim
Retmachinist
635
22
Urbandale Ia
I'm not sure what you mean "to fit into a 3 piece bottom bracket?" Milling wouldn't be an option. There are ways to cut square holes, broaches, E.D.M.'s, lazers, water jet, also not sure why you need a tapered square hole? Explain.
John
Sep 20, 2008
1,668
12
Clearwater, FL
web.tampabay.rr.com
I think he's talking about the pedal crank shaft.
I've got the 3 piece set-up on my Spoilers. The shaft is square and tapered at the ends 2-3 degrees.
The hole in the crank has a corresponding square, tapered hole so that the crank is forced onto the taper for a positive fit. There is a bolt that draws the crank onto the shaft.
Jim
junkyard
82
st.petersburg fla
Jim
you said the magic word....expensive
ok even tho i love the clean look of the bottom bracket jackshaft im probly gunna try to use a steel hub like i did on my electric drive conversion
thx for the info
junkyard
82
st.petersburg fla
John
yes what jim said....to fit onto the bottom bracket like the crank would....sorry for any confusion
edit:the idea was to make a piece for one side to mount 2 freewheels back to back and a piece for the other to mount the larger sprocket to the engine......both pieces would bolt onto a standard bottom bracket
but the idea revolved around making the square tapering hole like a crank arm has
Retmachinist
635
22
Urbandale Ia
Jim
O.K. I am with you guys now. I thought at first he wanted to cut a tapered square hole through the bottom bracket, just tapered at one end. I couldn't figure out what you could use it for.
Got it now.
John
